1989 Porsche 944 Air conditioning and fresh air blows very
1989 PORSCHE 944
122,000 MILES • 4 CYL • 2WD • MANUAL
SEAN BAILEY
I have an 89 Porsche 944. The other day as I was enjoying my A/C on a very hot day, the air through the vents, started blowing hot air! Hotter than outside air! I closed the vents and turned on the recirculation button. That made it bearable but not cured! By morning, my new battery was dead! I had the battery checked and I have a half an amp draw on the battery. I was told that it is probably a clip that holds the rod that controls the flaps inside the air box and now the rod is stuck. This would explain all issues but I cant find the area that the clips should be in to even see if that is it, I have bought a complete used airbox that is being shipped to me now but would like to know if there could be something else that I may be able to fix? Can someone help me asap please!!!! Thank you, Sean
Aug 2, 2009 at 2:34 AM
2 CARVINCE
  • 31 POSTS
You can check to se if the flaps are working by looking dash right of steering column . you might have to remove a trim piece , but once exposed you will see the side of air box and can see the end of the rod the flaps are on .if moving or not .
Jan 19, 2010 at 9:25 AM
