1983 Porsche 944 alternator
12,000 MILES • 4 CYL • 2WD • MANUAL
HERBG1931
I have had my alternator tested at a parts store and it checks out good. My car manual says that if the dash indicator light stays on, the alternator regulator is bad. I replaced the regulator and the light stays on but the system doesn't charge (only 12 volts at the battery). I friend of mine said to remove the excitor wire and jump 12 volts to the alternator while the engine is running. Doesn't work either. How can I check the alternator internal windings etc to see if it is the culprit.
Apr 15, 2009 at 10:37 AM
JAMES W.
  • 2,394 POSTS
If the alternator tested good, there has to be an "open" in the system somewhere.
https://images.2carpros.com/forum/automotive_pictures/248092_porsche_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248092_porsche_2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248092_porsche_4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248092_porsche_3_1.jpg
Apr 15, 2009 at 12:48 PM
