2002 Porsche 911 ignition switch
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
BILL IN ST. AUGUSTINE
Ignition switch doesn't want to release key, when the engine is running the lights, windshield wipers and AC will not work. When I turn off the ingition switch the lights, windshield and AC do work.
When I remove the key with a strong pull the dashboard information states "key in ignition".
What is the problem.
May 4, 2010 at 12:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try lubricating the ignition lock cylinder with WD40 and also use a spare key. If this doesn't help then the ignition switch will most likely need replaced.
May 4, 2010 at 1:06 PM
