How do I change the oil level sensor on my car. I cant find it>>>Where and how. Please help
Apr 28, 2010 at 10:57 AM
BLUELIGHTNIN6
✓Experienced Mechanic
there is no separate oil level sensor, just an oil pressure switch , the switch has the oil pressure sensor built in. the oil pressure switch is pretty easy to remove, it just unbolts from the engine block after you disconnect its electrical connector. it should have just 2 wires, a brown/pink wire and a green/red wire.
