1999 Porsche 911 Oil Level Sensor
1999 PORSCHE 911
148,000 MILES • 6 CYL • 2WD • MANUAL
AGEE11
How do I change the oil level sensor on my car. I cant find it>>>Where and how. Please help
Apr 28, 2010 at 10:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no separate oil level sensor, just an oil pressure switch , the switch has the oil pressure sensor built in. the oil pressure switch is pretty easy to remove, it just unbolts from the engine block after you disconnect its electrical connector. it should have just 2 wires, a brown/pink wire and a green/red wire.
Apr 28, 2010 at 11:15 AM
