1998 Porsche 911 oil pressure
1998 PORSCHE 911
MICKREAY
Engine Mechanical problem
1998 Porsche 911 6 cyl Two Wheel Drive Automatic 76k miles
my oil pressuse gauge is reading over five when i start my car and also when driving
also when i start me car there is smoke coming out the exhaust for about 20 seconds then it disapears i think as i cannot see smoke when i drive after that
Sep 2, 2010 at 9:04 AM
CWPORSCHE
  • EXPERT
  • 58 POSTS
Your engine will always read 5 bar when engine is cold,usually above idle.As it warms up it will decrease due to lower viscosity(thinner oil)If it reads 5 bar w/key on only then you may have a faulty sending unit. The reason it smokes at times on startup is because its either overfilled with oil or you oil separator is starting to leak vacuum which will suck oil into the intake and try to burn it. These engines by nature will smoke at times on startup depending on how long they sit due to the design of the crankcase.The oil level slowly rises above the cylinder walls then oil seeps past the rings causing a small amount of oil to burn off on startup.Hope this helps.
Sep 2, 2010 at 11:21 AM
MICKREAY
i have noticed that when i am driving it now there is blue smoke coming out the back and as i said on start up there is lots of smoke coming out
it has only started to happen in the last couple of days before that it was fine no smoke on start up and no smoke when driving
thanks mick
Sep 3, 2010 at 4:00 AM
CWPORSCHE
  • EXPERT
  • 58 POSTS
If this is a watercooled engine then it sounds like you have a bad oil separator. water cooled engines didn't come out untill 1999.
Sep 5, 2010 at 8:43 PM
