1983 Porsche 911 TUNE-UP & OIL CHANGE
1983 PORSCHE 911
SURFDOGG
Engine Performance problem
1983 Porsche 911 Manual
HOW DIFFICULT IS AN OIL CHANGE? DO I NEED ANY OTHER WORK DONE AT THAT TIME ,SUCH AS VALVE AJUSTMENT? CAN I TUNE IT UP MYSELF?
THANKS.
Sep 19, 2009 at 6:21 PM
2 CARVINCE
  • 31 POSTS
hello , anytime you do an oil change i is determind b mileage .valves should be adjusted every 15 ,000 miles . The valve adjustment is very important,and crucial and if adusted incorrectly can cause engine damage .Also at 15k the air filter ,spark plugs should be cleaned and or replaced .
Jan 7, 2010 at 6:22 PM
