1981 Porsche 911 Alignment
142,000 MILES • 6 CYL • 2WD • MANUAL
RON RICHTER
Each time I have work done on the suspension, steering, etc, and then requiring an alignment, I get a different answer whether my 911 needs to have just the front wheels aligned or all four.
Answer is?
Thanks,
Jan 20, 2010 at 7:37 AM
2 CARVINCE
  • 31 POSTS
when a alignment is performed all four wheels are checked . the rear wheel adjustments are locked down and the only time you have to adjust is if you lower or have an accident and the rear is damaged >
Jan 20, 2010 at 9:44 PM
