1980 Porsche 911 Power Windows - blowing fuse
121,200 MILES • 6 CYL • 2WD • MANUAL
RSWISER
With car off, I replace the fuse for the power windows. Turn key to "On" and all windows and switches work perfectly.
Turn on ignition and passenger window goes down about 3/4" with touching the switch, before the fuse burns out.
Repeat process, same result.
Where to start looking for this gremlin?
May 27, 2009 at 5:23 AM
  • 31,937 POSTS
Hi there,
If the window is over tight and slow to move this can over load the motor and blow the fuse, check this first, if so you can get specific window channel lube this may help, start here.
mark (mhpautos)
May 27, 2009 at 10:38 AM
