1974 Porsche 911 Carrera ignition trouble
1974 PORSCHE 911
FIFFE
Electrical problem
1974 Porsche 911 Carrera 6 cyl Two Wheel Drive Manual 105k miles
The car will start and run fine for a while and then
it will shut down and not start for about 15 minutes
there is no spark coming from coil. I have tested the coil and perma tune module, generator is working and system is charging. Heat does not appear to effect it as it happens when the engine is cold or hot.
1974 porsche 911 2.7L generator with external regulator
Jul 5, 2008 at 1:03 AM
JCLAX7
this is an old poursche. :D
Oct 18, 2008 at 8:13 PM
