pops out of gear while driving
200,000 MILES • 2WD • AUTOMATIC
DELLUNAA
  • 45 POSTS
While driving it will pop out of gear. Then have to pull over to side to put it into park and then into first and then into drive then take off again down the road. This lasts for a while and then it will repeat itself. The neutral safety thing that mounts near the bottom of the engine was replaced and the problem did not reoccur for about a year. It is now popping out of gear again. The most recent time it happened was while driving on a cobblestone street. This type of street caused a lot of vibration. That is about all I can think of.
Thanks for your help for my sisters vehicle problem.
Jim Felland (Hughlene Dunn is my sister)
Nov 27, 2019 at 10:48 PM
Good morning,
The first thing I would do is to drop the pan and change the fluid and filter in the transmission. It is possible the filter is clogged with debris.
I would start there.
Nov 29, 2019 at 10:57 PM
