aerostar is clicking
FORD AEROSTAR
DELLAROSA
I have a clicking sound under my hood when i start my 94 aerostar. I TRIED TO JUMP IT AND IT DID NOT HELP I THEN TAPPED ON THE BATTREYAND IT STARTED. The ticking sounds like it is coming from the alternator.
Aug 22, 2007 at 10:59 AM
SIMONK
  • 8 POSTS
the clicking might be coming from the starter because its not getting enough current.Check your bettery terminals for cleanliness from corrosion or loose ground cable.
Aug 22, 2007 at 2:56 PM
KMULLINEX
I had an identical problem with mine and after much trial and error it turned out I needed a new battery cable from the battery to the starter.
Sep 2, 2007 at 5:50 AM
