popping sound on drivers side wheel when turning
240,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
LIPPY4455
I hit a big pothole at work with my front driver's side wheel. Now every once in a while when i turn to the right i here a pooping sound. Then it goes away for a week or so and comes back, so i had it lubed up and it seems to have worked. What if it comes back?
Sep 16, 2015 at 10:58 AM
CJ MEDEVAC
  • 11,000 POSTS
AT MINIMUM,
I'D HAVE THE FRONT END ALIGNED
EXPLAIN YOUR "POOPING SOUND" TO 'EM WHEN YOU TAKE IT THERE
HOPEFULLY THEY WILL LOOK AT THE SUSPENSION STUFF A LITTLE HARDER, SOMETHING MAY BE BENT, OR SEVERELY DAMAGED. BEST TO FIND IT NOW, THEN WHEN YOU LOOSE CONTROL AND YOU REALLY HEAR "THAT SOUND"!
MAYBE THEY CAN LOCATE THE POPPING SOUND IN YOUR CHEROKEE TOO! LOL!
THE MEDIC
Sep 16, 2015 at 11:37 AM
