Codes P0193, P0420, P0430, P0506, popping sound from air intake?
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAYMOND777
The vehicle listed above has V6.
Recently it has been making a muffled popping sound intermittently from the air filter box. It runs fine. After having codes checked, it came back with the following; P0193 - P0420 - P0430 - P0506.
Jul 22, 2022 at 7:11 PM
  • 55,694 POSTS
The P0193 code is the one that can cause all of these problems, fuel rail sensor. Here is the location and how to change it out in the diagrams below with a video of the job being done on a similar car:
https://youtu.be/A9dbXbydGro
Jul 23, 2022 at 4:29 AM
RAYMOND777
Thank you Ken. I will order one from Amazon and let you know how it went.
Jul 24, 2022 at 3:26 AM
  • 55,694 POSTS
It is the best way to go when fixing these kinds of problems.
Jul 24, 2022 at 3:27 AM
RAYMOND777
Ken, you are a genius! I never suspected that all these codes could be caused by a single malfunctioning part. I replaced the fuel rail pressure sensor as you said and the codes have cleared. The vehicle is running normally again.
Many thanks to you all!
Raymond
Aug 10, 2022 at 9:23 AM
  • 55,694 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Aug 10, 2022 at 10:08 AM
