Popping noise on acceleration, front end?
170,000 MILES • V6 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
I noticed that upon certain acceleration that there is a popping noise that seems to be coming from the driver's front side. It doesn’t do it upon slow acceleration, just when enough acceleration is applied that it lifts up the front of the car. On this vehicle there is only one ball joint on the lower control arm. Could it be the ball joint? The control arm? Something else?
Jul 15, 2025 at 10:58 PM
  • 55,684 POSTS
Oh, yes that is a noise all right, I would not drive it anymore until the noise is fixed, it sounds like an engine mount or mounts are gone. This allows the engine to move excessively. What you hear is the engine or exhaust contacting the frame. To confirm, open the hood and then start the engine, have a helper put the car in drive with the foot on the brake firmly, then put the car in drive and give the engine a very slight amount of throttle and watch the movement. This will help confirm the issue. Please upload a video in your response so I can see.
Jul 16, 2025 at 12:06 PM
BEETLEPUNK21
  • 127 POSTS
You were right! It was the engine mount! Totally gone. I repaired it and it fixed the issue. Thank you for the help and great information! You guys rock!
Jan 19, 2026 at 11:30 PM
  • 55,684 POSTS
Glad you could get it fixed, thanks for letting us know. Ken
Jan 20, 2026 at 1:20 AM
