Popping noise in the front end
2017 CHEVROLET SILVERADO
26,300 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RCLILEN
I just had a 6.5" lift installed and now I am getting a popping noise when I turn. It started yesterday but stopped, and now it is doing it again. Any ideas?
Jul 13, 2018 at 2:03 PM
STEVE W.
  • 15,322 POSTS
It could be anything from a bad ball joint, steering box, tire rod binding. If you are setting still and rock the wheel does it pop? Does it matter which direction you turn? Do you have to be moving to make it pop? What parts were installed for the drop? 6.5 is a tall drop and should have had pieces to drop the transfer case, steering, A-arm cradle and more.
I would have the place that installed it check it over as it could be something simple like a loose bolt, or it could be that the lift is causing the axles to pop and damaging them and the differential.
Jul 14, 2018 at 12:21 PM
