Backfires
2007 FORD FREESTAR
120,000 MILES • 4.2L • V6 • FWD • AUTOMATIC
D122402P
Poor take off & hesitation. Replaced iac valve & cleaned throttle body. Almost acts like it's up againist the rev limited if u idle up quickly
Jun 2, 2014 at 2:46 PM
  • 110,240 POSTS
Has the check engine light come on? Here is a guide that will help find and fix the backfire issue.
https://www.2carpros.com/articles/engine-backfires-while-running
Jun 2, 2014 at 9:55 PM
D122402P
No it has not come on but, it is working. Thanks for the guide I found the camshaft had a flat lobe. What a great resource this site is I love it.
Jun 3, 2014 at 12:06 AM
  • 110,240 POSTS
This can help as well
Jun 3, 2014 at 1:34 AM
LOCAL 25
engine runnin rough and backfiring
Mar 10, 2019 at 4:39 AM (Merged)
Engine running rough or misfiring can be cause by the following:
1.Defective spark plugs
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
12.Mass Airflow Sensor
13.Idle air control valve
Note: If it doesn't apply disregard it-
KCBRISSET
2004 ford freestar stall while driving then when go to start again it takes about ten trys before i can go then start to putter almose want to back fire so change the fuel filter now puter n want to back fire but kills instead
Check the fuel pressure if its within specs fuel pump could be on its way out-also the engine coolant temperature sensor and idle air control valve/MAF sensor
