Popping/clicking noise coming from the rear of the vehicle when backing and turning
2014 FORD ESCAPE
84,000 MILES • 1.6L • 4 CYL • TURBO • 4WD • AUTOMATIC
JAY5353
I just had the rear CV axles replace. Pepboys says my rear shocks are bad. Can that cause the noise i am hearing?
Mar 22, 2021 at 10:03 AM
  • 110,244 POSTS
When you hear the noise, does it change with the speed of the vehicle? In other words, does the sound speed up and the wheels spin faster? I'm asking because shocks could make noise over a bump, but usually not when backing up or turning. Also, if you apply the brakes does the sound stop or change?
Is the sound loud enough that you could record it and upload it for me to hear? Also, were the CV axles replaced because of this noise, and are you certain it is the rear?
Mar 23, 2021 at 11:47 AM
