Ignition switch replacement?
150,000 MILES • 6 CYL • 2WD • MANUAL
SIMMI46
I drilled my ignition out because I broke the key off in the ignition I figured I would be able to get the steering wheel to the accessories position in order to be able to pop the clutch. little did I know there was much more involved. so my issue is. I now have ignition that is drilled out and a steering wheel that is still locked. how can I unlock my steering wheel? I don't have the money for any type of help. I'm stuck on the side of the road that is why I am online asking a free service. can you please help me? by the way I am also a blond, LOL.
Jun 25, 2020 at 12:18 AM
Okay, I found a YouTube video on replacing the switch with diagrams below to show you how as well.
https://www.youtube.com/watch?v=4W2RlVIVk1o
I would still like to see the column and the condition of the cylinder.
Oct 5, 2020 at 8:03 AM
HENSONJR
Electrical problem
1994 Nissan Truck 4 cyl Two Wheel Drive Manual
My key broke off in the ignition. At first I could turn it with the remaining portion of the key. Now, it won't turn at all. How do i get the tumbler out of the ignition housing. I got the wiring harness off the back, but, haven't gotten any further. I'm hoping I dont need to be able to turn the key in order to remove the tumbler.
Oct 7, 2020 at 4:59 AM (Merged)
CARSANDAIRPLANES
  • 19 POSTS
Boy these are fun (sarcastic)! It can be done, but it is not easy. First, you can try to talk an auto-locksmith into selling you some key extractors. If that doesn't fly, here is how to remove the Ignition Lock Cylinder.
1. Remove the steering column plastic.
2. Disconnect the electrical connections.
3. The two studs that fasten the cylinder to a bracket that mounts the assembly to the steering column are actually screws. You can remove them by:
a. Using a hammer and ice-pick to break them loose or
b. Dremeling a notch on the top and then use a flathead screwdriver (recommended).
4. After then cylinder is off, you need to remove the core from the housing by drilling next to, and prying out two roll-pin retainers near the face-plate.
5. After the roll-pins are out, the core will come out of the housing and you will have access to the broken piece of key.
Ok, well thats pretty much it. Good luck and please feel free to reply if you have questions. Votes/feedback is appreciated.
DOC206
1991 Nissan D21 truck is sometimes reluctant to start, but will start eventually. When I turn the ignition key, there is silence, no clicking or starter turning, etc. What is going on?
does it crank?? did not see much of an explanation. is it ok if you get it started??
Oct 7, 2020 at 5:00 AM (Merged)
BLAIRDIANN
1986 Nissan Truck 4 cyl Two Wheel Drive Manual
how to remove ignition switch
MARSAT
  • 7 POSTS
take cowling off around steering colume, 6 screws, swith is held in by small screw. just unplug the other end.
DOC206
It doesn't crank while trying to start. When it does start, it runs great. This problem doesn't occur everytime I try to start the truck.
when it does not crank, check and see if you have power to the little wire at the starter motor. if you do, the starter is bad. if not, start at the ignition switch for power.
