Popping under acceleration
1998 CHEVROLET TRUCK
210,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
M144ME
I had very high idle. i changed the intake gaskets and plastic upper intake, put new distributor cap, wires, plugs, started engine and it starts easy idles fine, but under acceleration it hesitates starts popping. i let off and take it easy and it does not do it. It is like the timing is slow but the crows foot locks distributor so you cannot turn it. there are no timing marks on timing cover. just a pointer with a notch in it. any help would be appreciated. thanks
Feb 27, 2018 at 11:20 AM
Good evening.
Did the engine do this prior to this repair?
did you verify the wires were in the correct location in the distributor cap?
Feb 28, 2018 at 9:51 AM
M144ME
No it did not do this just idled at 1200 rpm after changing just about every sensor i could i changed intake gaskets fixed idle problem. Yes i checked wires twice it idles smooth no miss unless it is under hard acceleration it pops through intake. this weekend i am going to change crows foot that holds distributor down to old style so i can move it. i think timing chain has slack do to high mileage and distributor needs advancing. this had 195,000 when i got it. what do you think?
Feb 28, 2018 at 10:17 AM
Okay, you cannot adjust the timing. the distributor is actually the camshaft position sensor. the timing is controlled by the PCM. Moving the distributor will not change the timing at all.
Another issue the older Chevrolet's had was a worn camshaft. the lobes wear down and the valves do not move enough and it ends up backfiring through the intake under load. To confirm, you would need to remove the valve covers and run the engine and watch the valve movement.
Feb 28, 2018 at 10:25 AM
M144ME
Thanks for the response. if i have a worn lobe would i have a ticking from rocker arm out of adjustment? i am not ASE certified but have a 1968 Nova race car i built myself and race, but do not know much about computer cars. the engine runs smooth and no noises i am baffled as to why you cannot adjust timing. my buddy says computer does it, but there is no advance in the distributor how does that work? So it is useless to put a timing light on it? I have not done that because there are no timing marks on timing cover? How do i find out where the timing is at?
Feb 28, 2018 at 10:35 AM
You need a scan tool that can read the timing. it is under total control of the ECM.
There will be no ticking from a lifter due to the fact only the lobe is worn, not the base of the cam.
Feb 28, 2018 at 10:38 AM
M144ME
Thanks for the information. i will try to get checked out and get back with the results. your help is greatly appreciated. Travis
Feb 28, 2018 at 10:40 AM
You are welcome.
Keep us updated.
Feb 28, 2018 at 10:41 AM
