Popping intake and exhaust at idle
2011 FORD RANGER
204,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
DAVE789699
rough idle. Replace TPS, plugs wires, looked at cams timing. look good.
Jan 5, 2020 at 6:15 PM
  • 110,194 POSTS
If you hear a back fire, there are only a few things that can cause it. If the timing is good and compression isn't an issue, chances are you are getting too much fuel. Take a look through this link and let me know if it helps. Also, let me know if there are any diagnostic trouble code and if you have a live data scanner. If you do have the scanner, I need to know what the short term fuel trims are.
_______________________
https://www.2carpros.com/articles/engine-backfires-while-running
Jan 5, 2020 at 8:53 PM
