poor running when cold
127,000 MILES
HUNK48
1.8 TDCi
Had service - repaced air and oil filter. fresh oil. new battery. replaced all glow plugs. replaced fuel filter. Within last 6 weeks replaced dual mass clutch and flywheel. Car starts first time. Idles most of time when cold. Put foot on gas engine dies. Ok when engine hot.
self diagnostics show
P0234 turbo/super charger overboost condition
P1664 injection pump control module malfunction
May 12, 2013 at 8:01 PM
1664 is the issue. there is a fault in the injector pump that is causing this. you need a shop to check this for you. codes never identify bad parts, just failed systems
May 14, 2013 at 11:40 AM
