Poor fuel economy
108,500 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KHALIDDVD
  • 56 POSTS
I have very high noted fuel consumption, really the same distance become consume about double quantity of fuel than it does before. no check engine warning,the ignition plug seems good and no seen drivability problem.
Sep 22, 2019 at 10:40 PM
BMDOUBLE
  • 1,139 POSTS
there are many factors that come into play when addressing fuel mileage concerns. I always address the first things that I see, and disregard if you have done some of these check already, wheel and tire size and pressure: are they the factory size and is the pressure correct. The tire pressure spec is on the driver door jamb sticker. Second: Maintenance, air filter, oil and filter, spark plugs. Even if they seem good, they have an expiration date in regards to the miles on the vehicle. Third: Trouble codes in the power-train control module. Even though the service engine soon light is not on, There could be continuous memory trouble codes in the background. Fourth: turn on the vehicle and view the fuel trim pids (if you have a scanner with this capability), they should be within 10% of 0. They PCM will not set a code until the fuel trims exceed 15% for a calibrated amount of time. I replaced the intake gaskets on my daughter's corolla because the rubber gasket was hard as a rock and allowed unmetered air to enter the intake on a cold start-up. Your mileage is right at that point where these gaskets go bad fyi. If the thermostat has not been replaced yet, I would recommend doing that because a stuck open thermostat will leave the vehicle in closed loop operation, which is a fuel rich cold start operation. Just a few basic things for you to check, hope this helps!
Sep 23, 2019 at 2:57 AM
