I have replaced new spark plugs, ignition coils, throttle body, and catalytic converters and sensors.
Jul 31, 2023 at 6:56 AM
✓Experienced Mechanic
I would check the air filter and if it is okay. Let's do a fuel pressure test because it sounds like the fuel pump is weak. Here are two guides that can help us with instructions on how to change the fuel pump in the images below:
