pigtail crankshaft sensor wiring?
30,000 MILES • 3.9L • 3 CYL • AUTOMATIC
CECILY
Aftermarket Pig Tail wiring. How to hook it up to my wires that is black/red, red and green.
Nov 9, 2024 at 1:30 AM
  • 55,808 POSTS
Sure, here is the engine crankshaft wiring diagrams so you can see how the wire connect, as you look a the connector straight on with the safety tab on the top, the terminals go 1, 2 and 3. Check out the images (below). Let us know if you need anything else.
Nov 9, 2024 at 8:28 AM
