2006 Pontiac Vibe 2006 vibe
52,500 MILES • 4 CYL • AWD • AUTOMATIC
INTHEBARREL
i have 2006 pontiac vibe.. it will stall and at times will not respond to me giving it gas--just goes at idle speed. the check engine light is also staying on. took it to advance automotive today and they hooked to computer to get code 607 which shows as a control module. they showed no control module that could be ordered for the vibe or where even the module would be on the engine. what next?
Mar 22, 2009 at 8:14 AM
BRIAN 1
  • 1,030 POSTS
p0607 is Control Module Performance.its an internal fault in the PCM.DTC P0601, P0604, P0606, P0607 or P2610 sets when the powertrain control module (PCM) has determined that the control module has an internal fault. The PCM performs continuous self checks of all internal circuits. If the status of an internal memory circuit within the control module is incorrect, a DTC P0601 or P0604 sets. If the inputs or outputs from the 2 central processing units (CPU) within the control module deviate from the standard level, a DTC P0606 or P0607 sets. The control module has several internal clock or timer circuits. The DTC P2610 diagnostic monitors the internal timer circuit responsible for the ignition OFF operation of the evaporative emission (EVAP) system vacuum leak pump. If the there is an error in the control module timer, a DTC P2610 sets.the diagnostic on this code is pretty basic,replace the pcm.post back with any other questions.
Mar 23, 2009 at 9:55 AM
