2005 Pontiac Vibe rotor removal
CMIDDLETON
How do you get the front rotors off?
May 16, 2009 at 5:27 AM
MMPRINCE4000
  • 8,548 POSTS
Remove caliper and hang out of way, remove pads and bracket.
Rotor may be rusted on spindle, a few gentle taps with a rubber hammer should pop it off.
Some manufacturers use small clips on the studs to hold rotor on during assembly, if you see one or two on there, remove them, they do not have to be replaced.
Jun 9, 2021 at 5:28 AM
