I'm not able to get the tire to come off. All the lug nuts are off but the tire won't budge. What's the problem???
Jun 19, 2010 at 7:16 AM
FACTORYJACK
✓Experienced Mechanic
Factory wheel?, it could be stuck on due to corrosion of the hub/aluminum wheel. If you rotate it, and beat on it with preferably a rubber mallet, at opposite sides each time, it should come off.
Jun 19, 2010 at 11:03 AM
