2004 Pontiac Vibe abs light and brake light
80,936 MILES • 4 CYL • AWD • AUTOMATIC
RONWILBORN
my abs light and brake light is on I replaced the right nuckle strut and control arm what do i need to check or how do i get the lights out the car stops fine
Jul 9, 2010 at 12:01 PM
SATURNTECH9
  • 30,869 POSTS
Was the abs light on before you change the knuckle?Also best thing to do is to get your abs computer scanned for code's unless you caused the light to come on when you changed the knuckle then i would be checking the harness to that wheel and make sure you didn't damage the sensor.
Jul 9, 2010 at 1:41 PM
