HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Vibe
General
Noises
Thump
2004 Pontiac Vibe
ST6465
MEMBER
2004 PONTIAC VIBE
4 CYL
2WD
AUTOMATIC
111,000 MILES
I have a thump or a click sound under the dash on the passenger side when car is running.
Saturday, February 7th, 2009 AT 9:39 PM
MMPRINCE4000
MECHANIC
Raise car, put on stands. Inspect passengers side firewall area for loose exhaust shields, loose bolts, missing exhaust hangers.
If noise is there when car is moving, then also inspect inner CV boots for leaks as well as axle bearings.
Also inspect motor mounts for wear.
Saturday, February 14th, 2009 AT 6:37 AM
Please
login
or
register
to post a reply.
Related Noise Thump Content
Outside Air Vent 'thumping'
Hear A Small 'thumping' In Dash (like Tapping Your Hand On The Dash) When Push Button To Open Outside Air Vent. Thumps 9 Times, Then Makes...
Asked by
ClarkHyv
1 ANSWER
2003
PONTIAC VIBE
2004 Pontiac Vibe Squeak/wine - Engine At Idle
For The Past 40,000 Miles, I Have Had A Noise Problem. I Had It In To The Dealer Several Times But He Could Not Duplicate It (or Did Not...
Asked by
wflansburg
2004
PONTIAC VIBE
Clicking Noise In Dash Passenger Side
2004 Pontiac Vibe Clicking Noise In Dash Passenger Side Even Engine Off And Key On Accessory What Could It Be? Safe To Drive To Repair Place...
Asked by
pfranklin
1 ANSWER
2004
PONTIAC VIBE
Ticking Sound From Vibe Ac
My 2003 Pontiac Vibe Has A Ticking Noise Coming From The Area Of The Vent Immediately Left Of The Glove Compartment When The Fan Is On. If I...
Asked by
rbyronh
2003
PONTIAC VIBE
Popping Noise In Dash
We Have A Regular Slow Popping (clicking) Noise When The Ignition Is Turned On Coming From Within The Right Side Of The Dashboard. If You...
Asked by
jblindsley
1 ANSWER
2006
PONTIAC VIBE
VIEW MORE
Howling
Grinding Noises
Change Engine Oil and Filter Ferrari 458
