2003 Pontiac Vibe Trouble Code
132,000 MILES • 4 CYL • FWD • MANUAL
TUGGLE
I recently had codes read for my Check Engine Light. I was told the Catalitic Converter was clogged up. The Car runs Great, No hessitation, no stumbling, No rotten egg smell. Just an annoying light. Any thoughts?
Aug 24, 2009 at 1:57 AM
MMPRINCE4000
  • 8,548 POSTS
A clogged convertor will cause driveability problems, hesitation, loss of power.
The code they probably got was a downstream O2 sensor "effeciency below threshhold", this is generally fixed by replacing the downstream O2 sensor(s).
A convertor backpressure test will confirm if convertor is clogged.
I would get a second opinion and if it is an O2 sensor, I would avoid the shop that wanted to replace the convertor.
Factory Toyota convertors are NOT cheap.
Sep 1, 2009 at 11:47 PM
