2003 Pontiac Vibe Cruise Control
272,000 MILES • 4 CYL • 2WD • AUTOMATIC
G_DRAIN
The crusie control works normally for 45 minutes or so, then starts shuting off by itself. It can be reset, but will shut off by itself shortly. The "cruise" light on the dash stays on, but I have noticed that the light will flash off then back on at the same time that the cruise control shuts off. Next trip, I use the cruise daily, it will work normally for 45 minutes or so then the failure repeats. This has been a progressive issue. First started happening after long trips in the summer heat. Has progressed to happening in mid-winter after short trips.
Jan 31, 2010 at 11:22 AM
MMPRINCE4000
  • 8,548 POSTS
It could be cruise module, or brake switch, parking brake switch, both of which will disable cruise.
Jun 30, 2010 at 1:47 AM
