What is the average cost to fix the blower fan, and if I do not use the fan is it OK for awhile?
Apr 25, 2009 at 8:21 PM
✓Experienced Mechanic
If you can adapt to your local weather w/o the heat or AC you'll be fine till you get it fix. See below
Labor cost varies with location could range from $70 to $125.00 per hr.
