2003 Pontiac Vibe check engine light
132,000 MILES • 4 CYL • FWD • MANUAL
VIBEDRIVER
I have a trouble code (P1692 Coolant Gage Circuit High Voltage). Does this mean it's the coolant temperature censor gone bad???
Nov 23, 2009 at 4:54 AM
MMPRINCE4000
  • 8,548 POSTS
Many cars have two senders, one for the PCM (coolant temp sender) and one for gauge (coolant temp gauge sensor).
Check with Pontiac and see if you have a coolant gauge temp sender, if so replace it, if not replace coolant temp sensor.
Dec 4, 2009 at 11:44 PM
