2003 Pontiac Vibe Catalytic Converter
2003 PONTIAC VIBE
114,000 MILES • 4 CYL • FWD • MANUAL
PONTIACVIBE2003
I had my cats changed last year, but my check light is back on for a PO420 cat efficiency low bank 1. The mechanic says I need a heavier cat, but the muffler guy says the cats may not be the problem. What do you think?
Aug 18, 2009 at 5:04 AM
WINEBURGER
  • 82 POSTS
the platinum group metals burn up excess fuel in the catalytic coverter. scrap large gm converters are worth $75 aftermarket converters are worth $5 aftemakets have alot less platinum in them.the o2 sensor takes a readind before and after from two diffrent sensors the diffrence between those two are the efficiency. so faulty o2 sensors is less likely than a aftermarket converter
Aug 18, 2009 at 5:32 AM
