2003 Pontiac Vibe Car is making noise in the front end
2003 PONTIAC VIBE
110,000 MILES • 4 CYL • FWD • AUTOMATIC
BRIGGSANDSTRATTONBOY
My car is making noise and its coming from the front end and it kindof gets louder the faster you drive but it doesnt make the car shake. When turning to the right it stops almost completely but when i go straight or left it gets loud.
Thank you ahead of time for any help.
-Briggsandstrattonboy-
May 8, 2009 at 4:44 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Jun 10, 2009 at 12:38 AM
