Clean Battery Acid Spill?
PONTIAC TRANSPORT
FRANCHISE
  • 7 POSTS
A car battery (same car) accidently spilled its acid onto my trunk carpet of my 2002 Trans Am when I was transporting it. I have tried the Autozone cleaners, but have had no luck. It turns towels to dust when left to try to absorb it. It leaves its smell/texture on items/hands that come into contact with it. What do I do?
Is it cleanable?
Any ideas?
Thanks,
Franchise
Mar 22, 2007 at 1:40 AM
MCFERRANCE
  • 100 POSTS
Common household baking soda should neutralize the acid. Some auto parts stores have a spray battery cleaner also that does the same thing. Neutralizing the spill is probably the best you'll be able to do as if there is a stain, which there most likely is, the only way to correct it would be a dye such as coloring dye for clothing.
Mar 26, 2007 at 3:54 AM
FRANCHISE
  • 7 POSTS
Thanks for the info.
Franchise
Mar 26, 2007 at 5:17 AM
