2006 Pontiac Transport problem starting
2006 PONTIAC TRANSPORT
98,000 MILES • 6 CYL • FWD • AUTOMATIC
BLUE_ROOT
starting the ignition turns over the engine OK but sometimes it koncks out unless you feather the gas a little.
It cranks over OK so I figure the starter is good, but Mr. Lube said that the battery has low cranking amps.
Should I change the battery or do I need new plugs & wires?
Aug 5, 2009 at 8:46 PM
Why don't you clean out the idle air control valve and see what happens
Aug 5, 2009 at 10:33 PM
