1998 Pontiac Transport ENgine turns over, but i don't think
1998 PONTIAC TRANSPORT
LILLITHREE
  • 5 POSTS
Engine Performance problem
1998 Pontiac Transport 6 cyl Front Wheel Drive Automatic
THe van was driving fine, but when we came out of the store and tried to start it, it sputtered like it was out of gas. After a few attemps it quit sputtering. I've checked all the small fuses in the fuse box under the hood, and tried replacing the fuel pump micro relay. I've only had this vehicle for two days and its the only I have to get the kids to thier appt's. any help would be appreciated. Thank you.
Jun 21, 2009 at 7:35 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is the problem still there? does it run? A check of fuel pressure is in order. How new are plugs filters wires etc.?
Let me know
Thanks for donate
Jun 21, 2009 at 8:03 AM
LILLITHREE
  • 5 POSTS
I am not sure how new the wires and plugs are. It is firing great, not missing a beat..... turns over fine. Battery is real strong. Even tried giving it gas from inside the hood, instead of the peddle. nothing, you can tell not a drop is getting in there...... it's like it is empty.
Jun 21, 2009 at 8:26 AM
DOCFIXIT
  • 18,828 POSTS
Spray some carb cleaner into throttle body see if it lights. Need to check fuel pressure. Should be able to hear pump in tank run when key on.
Jun 21, 2009 at 8:32 AM
LILLITHREE
  • 5 POSTS
Tried to find the spot to check fuel pressure, according to where the haines manual said it should be, behind the power steering . but it's not there. question, if it totally ran out of gas, and i put a two gallon can in it. would that be enough for it to start up, and would I have to do anything special. when you know on the tank underneath. it sounds empty, not like there is something in the bottom.
Jun 21, 2009 at 8:59 AM
DOCFIXIT
  • 18,828 POSTS
If it ran out 2 gal not enough can you hear pump run. Often times when tank run dry it pulls alot of debris into pump and takes it out.
Jun 21, 2009 at 9:20 AM
LILLITHREE
  • 5 POSTS
Sent husband to get a 5 gallon can of gas and a fuel filter incase of debrie. he said something about having to bleed air out of the gas line, he thought, if thats what it was?
Jun 21, 2009 at 10:12 AM
DOCFIXIT
  • 18,828 POSTS
Air should self bleed not like a diesel where you have to bleed after system open.
Let me know what happens
Jun 22, 2009 at 4:35 AM
LILLITHREE
  • 5 POSTS
it was the gas, not enough in it. It still says get engine checked soon though. and I noticed "low coolant" comes on alot, it seems to over heat to. and the vents dont blow out much air. any ideas? did I buy a "lemon"?
Jul 2, 2009 at 8:24 AM
DOCFIXIT
  • 18,828 POSTS
Go to an Auto zone they will read codes then post.
Try coolant flush and a thermostat. Is air volume low? all fan speeds work?
Jul 2, 2009 at 8:29 AM
