1998 Pontiac Transport Engine Mount Torque Strut Brackets
110,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBG
I need to remove the engine mount torque strut bracket on the passenger side. I found only two bolts, the upper bolt and the one on the far left I can't find any others, even when I use a mirror to inspect the bracket. The bracket won't budge. Any idea where the bolt(s) is located?
Jan 13, 2008 at 8:00 AM
BOBG
I figured it out. Two bolts from the AC compressor must be removed, and a third bolt must be backed out about 6 turns. The repair manual does not mention this at all.
Jan 26, 2008 at 1:16 PM
