1998 Pontiac Transport engine cooling
JAYMO
  • 1998 PONTIAC TRANSPORT
i have replaced the water pump and the thermoststat, but cant get the air out of the system.
Friday, October 17th, 2008 AT 11:51 PM
BLACKOP555
  • 10,371 POSTS
Jack the front end of the vehicle up high and let the engine run till its hot with the radiator cap removed. If that isnt plausable sicne you may have a radiator without a cap you could loosen up the upper radiator hose and put a screwdriver in there and pry up on it to release some air.
Saturday, October 18th, 2008 AT 8:45 AM
