1997 Pontiac Transport Rack and pionin
1997 PONTIAC TRANSPORT
LIGHTISYESHUA
Steering problem
1997 Pontiac Transport 184000 miles
I have owned this van for 5 years years. I have replace this part 4 tmes nd need to do so again. About every 20,000 miles. Is this normal? Is this a typical engineering problem? The mechanic has replaced the part under warranty put I still have to pay $210 for labor each time because it is outside the 6 month 6,000 miles that it starts to leak again. Am I being taken?
Sep 18, 2010 at 3:52 PM
MERLIN2021
  • 17,250 POSTS
A lot depends on the rebuilder of the part(s), try using a better part, and are they flushing out the pump and lines? Could be some metal debris in the fluid.
Sep 19, 2010 at 2:43 AM
LIGHTISYESHUA
Last time they replaced it they said that they used a better part and we did flush the power steering fluid. Could it be a problem with the power steering pump?
Sep 20, 2010 at 3:26 PM
MERLIN2021
  • 17,250 POSTS
The pump would need to be pressure tested to answer that, does it whine? Hard to turn? Too easy to turn? Pull to one side? Steering wheel turn by itself in park?
Sep 21, 2010 at 9:34 AM
