1997 Pontiac Transport
81,000 MILES • 6 CYL • FWD • AUTOMATIC
ZACHMAG
The Pontiac transport Montana has a 3.4 engine. At interstate speeds, it will irratically cut out briefly, and then run smooth again. I am unfamiliar with the vehicle, but my guess might be the breaking down of the coil.
What do you think it might be?
Thanks for your time.
Sep 28, 2010 at 1:51 PM
BUDDYCRAIGG
  • 2,262 POSTS
intermittent stumbling is almost impossible to figure out.
It needs to finally die to test if you are missing spark or fuel.
about the coil, generally when GM modules or coils die from heat, they stay dead until it cools off for a few hours. So I don't expect that to be the problem.
Sep 28, 2010 at 2:43 PM
