Heat coming out not as hot as should be. Doesn't have the air blowing out as hard either. Could this be a clogged heater hose? And if so how do i locate the proper hose to check? Could it be a fuse? What do you recommend i look for?
Jan 22, 2009 at 9:15 AM
