1996 Pontiac Transport Power Drain When Cranking
1996 PONTIAC TRANSPORT
18,600 MILES • 6 CYL • FWD • AUTOMATIC
REHFELDT
I was not the primary driver on this vehicle. The vehicle sat for about 3 weeks and needed a jump. It sounded very rough when I jumped it and I was told it had been running like that for a while. The negative clamp(grounded properly)started smoking for a sec when it was cranked then stopped as the engine caught. The vehicle drove about 1/4 mi. and died (ironically by a used car lot, who were kind enough to let me try their jump box when a car jump didn't work) When I tried to rejump it I had a hard time getting a good connection. When I did get a connection, all the warning lights came on and the voltage showed around 12 on the dash gauge. When I cranked it, it turned half way and the voltage dropped to nothing. I checked and replaced the battery which was weak. It still does the same 1/2 turn and drains the voltage, so I unhooked the new battery for now. This van was/is 60 miles from home and I had no diagnostic tools. I will go back tomorrow and try to get it running enough that I can get it home and work on it properly. Do you have any suggestions on where to start?
Nov 23, 2008 at 1:13 AM
  • 31,937 POSTS
Hi there,
Make sure that the battery clamps are clean & tight, check all the earth connections and if it is still hard to crank, i would be suspecting a poling starter motor, start here.
Mark (mhpautos)
Nov 23, 2008 at 1:20 AM
REHFELDT
[quote:be7ce3fdb2="mhpautos"]Hi there,
Mark (mhpautos)[/quote:be7ce3fdb2]
The vehicle died while operating and then wouldn't restart... would the starter kill a running vehicle?
Nov 25, 2008 at 3:16 PM
