1996 Pontiac Transport
SPUNKY328
1996 Pontiac Transport Automatic
At first my car would die after 8 miles of driving it.... So I changed the ignition module the coils the and the fuel filter still didn't solve it finally started running again after I cut off the converter but was running rough... I put new spark plug cables on and after I did this it will not start it cranks over like it wants to but won't go beyond that.... Any ideas as to what can be the next problem?
Dec 28, 2009 at 5:23 PM
  • 75,988 POSTS
Are you getting spark?If so,check your fuel pressure.Come back with the readings.
Dec 28, 2009 at 5:42 PM
SPUNKY328
[quote:e2819a225e="rasmataz"]Are you getting spark?If so,check your fuel pressure.Come back with the readings.[/quote:e2819a225e]
Yes I am getting a spark and pressure is fine
Dec 29, 2009 at 3:08 AM
