1992 Pontiac Transport WIPER MOTOR LOCATION
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
IRFBAF
HOW DO I GET AT THE FRONT WIPER MOTOR TO TEST IT?
Feb 8, 2009 at 7:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The wiper motor is located in the engine compartment, above the engine, offset to the passenger side. Just remove it slightly without disconnecting the wiring to test it. Using a 8mm socket, loosen the two crank arm socket screw and lockwashers until the socket releases from the crank arm ball.
Do not remove the crank arm from the motor.
Using a 10mm socket, remove the three motor retaining screws.
Slide the motor out of the slot in the bracket.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 8:29 AM
