1992 Pontiac Transport coolent leak
1992 PONTIAC TRANSPORT
MJRYDECKI
1992 Pontiac Transport 6 cyl Automatic 125000 miles
Loosing coolent, thought it was the waterpump. replaced it. still leaking near there down under. What else could it possibly be?
Mar 11, 2009 at 8:50 AM
SOPERM1
If this is a 3100 or 3400, then it is probably a defective intake gasket. GM went cheap and used a plastic encased gasket that fails often. U can usually see a small stream or remnants of coolant behind the power streering pump nest to the intake manifold/uppr plenum. Otherwise, check the coolant bypass tube behind the waterpump, they like to rust and fail also.
Mar 15, 2009 at 5:40 AM
