1987 Pontiac Trans Am Timing
1987 PONTIAC TRANSPORT
EARNIEKEYSER
Engine Mechanical problem
1987 Pontiac Trans Am V8 Two Wheel Drive Automatic
What would happen if the timing is off one notch? Will it overheat?
Nov 20, 2008 at 1:14 PM
JAMES W.
  • 2,394 POSTS
The ignition timing is controlled by the ECM and is considered no-adjustable. If the timing hasn't be tampered with, I would say you have another problem elsewhere.
Nov 22, 2008 at 8:12 AM
EARNIEKEYSER
The car is running hot after driving 65 mph or faster for 5 minutes. Under 65 mph it runs fine. The car has had a new timing chain installed and I was wondering if the chain was one tooth off (misaligned) could that cause overheating at high speed? Or maybe an obstruction in the radiator? The water pump was changed as it started leaking (the water pump was bad). It still over heats. What could be the problem?
Nov 22, 2008 at 12:36 PM
JAMES W.
  • 2,394 POSTS
Cam timing being off a notch would cause more performance problems than anything else. Did the overheating start after the new timing chain was installed? At this point, I would think your radiator is plugged.
Nov 23, 2008 at 4:19 AM
