2002 Pontiac Trans Am water leaking into car under passenge
45,000 MILES • V8 • 2WD • AUTOMATIC
THEDARTMAN
I have water pooling up under the passenger rear seat of my Trans Am convertible and was wondering if there is a drain hole/hose that may be clogged. I just have no idea where it would be located to clean it out. When I hit the brakes, the water rolls forward soaking the pass rear floor. Thanks for your help.
May 23, 2010 at 12:07 PM
MRBIGGDADDYWIGGS
I have a 2002 WS6 convertible too, if yo let your top down but not all the way and look into the side where if the cars had rear side windows and look down in there and you will see drain hole. Sometimes they get clogged up with trash. You have to clean them out and get a wire hanger (straightened out) and poke the holes out, mine had leaves and trash in them, I don't know how it got there. hopefully that helps.
Jul 3, 2011 at 7:52 PM
